french canal's
bogart
18 Oct 2001
Ireland
french canal\'s
is it possible to navigate from north france, ie english channel to the med, and if possible , what would the maximum allowable draft be.
Re: french canal\'s
Max. length 39 metres, max. beam 5.1 metres, max. air draft 3.5 metres, max. draft depends on the route but 1.8 metres at the most.
Re: french canal\'s
Try "cruising French waterways" by Hugh McKnight available to order from your local bookshop ISBN No:0-7136-5005-2
This will give you an insight to various routes and the legal requirments (cevni rules etc:)
If you are thinking of going soon,the canals are shut for approx 6 wks from beginning of Nov: Details from VNF (Voies navigables de France)++0033 326857595
Happy cruising
Re: french canal\'s
I heard draft depends on what time of year - rain filling canals etc. My draft is 1.35m - what would be a good time?
Re: french canal\'s
Just to chip in with some 'local' knowledge, it might be useful to remember that the Canal St-Martin, which cuts through Paris, has now been drained and is undergoing major works. So, forget cruising through the capital for a year or so!
Re: french canal\'s
Feb -March is flood season on the rivers,best avoided.Certain canals run out of water near summit(Bourgogne?)Try the afore-mentioned book, also Marion Martin has written a couple of books.Don't forget,if your a yotty type,your mast will have to be un-stepped and places that can do this are listed in these books.
Re: french canal\'s
Wouldn't think that 1.35m should be a problem any time of year on the more major routes. Canal levels will not vary that much and flooding is more of a problem on the rivers these days than drought.
