KevO
This is my prop. Anyone have any guidance about it's servicing requirements? Simple strip clean and reassemble? Special grease? Anything to watch out for in particular?
Clean it. Does not look like it has anodes. Check for play in the gears and play in the pivot pins.
Do what the rest of the sentence suggests. Clean it bit was just to indicate how little you need to do!Sorry mate, old photo used to show the type. It is clean now I just wondered what to do with it over the winter before launch.
Not sure what the wear tolerance is. Guess you have to ask Volvo. Wear usually manifests itself in noise - rattling and sticky operation.I have a 3 blade VP folding prop on my saildrive, there is a very small amount of play in the gears and pivot pins, but how much is 'too much' play?
Thanks, will try Volvo, but not easy to get answers from.
As all above have advised however re Woodlouse that grub screw is not for grease, it screws down onto the retaining nut to stop it from coming loose (after which your propeller falls off).
I remember someting about a place near Wareham that might service them...
It's possible to check the blade play and think they're OK when they're not. To check for wear on the blade gears where there is usually the most corrosion and/or wear, fold one blade out while pushing the other one in and check they don't bind at a range of angles.
