bob26
Having made a gas bottle box with ply covered in grp I tried to cover in flowcoat.
The bottom was fine - though it took a while to go off - but the vertical sides sagged horribly leaving ridges and cracks like the icefalls at Everest base camp.
Is it not possible to apply flowcoat on vertical surfaces or did I :
a. use too little hardener? or
b. work in too low a temperature (it was probably about 6-8 degrees C in my garage last night)? or
c. Not rough up surface enough?
Should I have left the grp laminate to cure longer - or applied flowcoat sooner?
As I understand flowcoat is gelcoat mixed with wax which creates a surface coat, presumably I have to grind all this mess off completely before I attempt to redo?
