CFG98
Only rainwater gets into my boat. Only need a small bilge pump. What is best? A float switch or a water witch type of electronic switch or an auto pump?
How you use your boat will inform your decision, e.g. if left for long periods on a swinging mooring some form of auto pump would be desirable. A lot of boats have a manual and an electric in case one fails or there's no power for the electric one and stating the obvious try if you can to find where the water is getting in and stop it from doing so. If there's one bilge area I'd probably go for a combined unit with an internal float switch...
Thanks. Is a float switch better than an electronic switch? I have read of debris messing with float switches or I thought I had. Will get a couple of different manual pumps too. Wooden boat so debris is often prevalent. Perhaps a strum box over the lot?
