DaveW
Hi All,
I need to replace my flexible water tank as it is leaking.
Not sure of manufacturer of original, which has an outlet pipe of 1.5 inches.
Have ordered a replacement Plastimo tank 150litre 140cm x 70cm, but on receipt have discovered that the outlet pipe is 12mm dia.
Went to price up a reducer from 1.5" to 12mm and that came to about £23 - half the price of the water tank.
Don't really want to replace all the hosing through the boat as it is awkward to fit. Other possibility, I supose, is to run smaller pipe through the original, but would have to change all the end fittings.
Does anyone know of other manufacturers other than Plastimo that produce Flexible water tanks with bigger outlets?
Thanks, Dave
Thanks, Dave
