fastjedi
How do flexible solar panels fix to the non slip surface on the coach roof?….. I may loose interest if it involves drilling holes!
We had flexible panels on our coachroof. They lasted about 2 years due to corrosion. I will never go flexi again. Useless compared to framed panels with regard to power output and durabilityHow do flexible solar panels fix to the non slip surface on the coach roof?….. I may loose interest if it involves drilling holes!
We use very wide velcro tape. Clean the surfaces with acetone to get the velcro to stick.
No problems after 4 seasons.
There are panels and then there are panels. Buying good quality marine panels mean you will pay a significant price, but they last and do what they say on the tin.
I have 4 SunWare 20 series stuck to the nonslip and a SunWare TX series on the spray hood. They work.
Would a Lift-a-Dot fastener in each corner not do? It would be very easy to remove or replace the panel when needed
The panel really needs to be flat, lift a dot would likely cause cracking at the corners. If you were going to screw lift a dots to the deck, may as well use a screw.
About to put 200 watts on my coach roof and am going with Dual lock after the mostly enlighting Discussion on this exact forum not so long ago
I never new velcro could cause such a thread
I will let every one know how I get on , but as for holes I have to many on my boat the less holes the better for me![]()
A 1" square of Dual Lock anywhere you'd put a screw will hold it nicely. No need for big long strips. :encouragement:
