asj1
I have purchased a horizontal axis elecric windlasss. This all fits on deck with minimum neccessary cut -outs (chain and cabling).
I was intending to fix it with a stout pad of hardwood circa 25/30 mm thick between it and the deck with the windlass through bolted.
My problem, which I am sure is quite common, is that the deck is slightly curved in this area. Therefore the hardwood pad needs to have a slight concave shape to it in order that it fits properly on the deck . This will be difficult to do ! Possible solutions that come to mind are;
1) Shape it as best I can and then bed it down onto sikaflex - probably the most straightforward solution , bit will it be firm enough?
2) try and make a flat bed from polyester resin by making a small frame and pouring the resin in to naturally find its own flat level. This would tehn not require any shaping of the hardwood pad. - will this actually work? does polyester resin 3-4 mm thick actually set properly?
3) work at getting a very good concave shape onto the hardwood pad so that the through bolting provides a good rigid fitting with only ordinary sealant round the edges - very difficult to achieve I think.
Any commenst from the forum/experiences to share?
What tool could I use to try and make a concave shape into a hardwood pad.
Regards
Regards
