webcraft
I want to fit a radar reflector, so will need to fix the brackets at four points. Echomax recommend using monel rivets, but I understand this needs a heavy duty rivetting gun which is expensive. Will aluminium rivrts be adequate for the job? I would have thought so.
Also - how do I know what size the rivets should be?
Am also planning to fit an external plastic conduit for the wires (yes, I know it should be inside - already had this discussion at length) and was going to use self-tappers - could I also fix this to the mast with rivets, and should I?
- W
- W
