fjweaver
not sure how to describe this but I'm fitting an electric socket on the outside of a wooden locker/wardrobe.
I will be cutting out a hole for the inner part of the socket to fit through but I'm not sure what cover to put on the back.
I don't want to use a 'dry-lining' type box as this would stand proud on the outside.
I won't be able to screw into the back with a normal white mounting box.
I need a sort of cover with screw hole on the outside of the box but i'm not sure if they are made or what they're called.
or is there something else i can use as a cover at the back to cover the exposed wiring?
hope this makes sense!
Frank
Frank
