kashurst
the temp sensor will almost certainly be a negative temperature coefficient thermistor (NTC). Very cheap, easy to get hold off. Just a question of finding an equivalent. They are not polarity sensitive either.
I installed Farsco's genius setup for boost pressure guages, and got the boat out today to test them. They worked perfectly, and the signal to the display on the flybridge was fine toi. Much kudos!
just ordered the BBQ thermometer - I will report back when I have figured out the sensors
pretty sure it will respond fast enough. The specific heat capacity of water is about 4 times greater than rubber. So if the cooling water is heating up, the rubber will heat up just as fast. The rubber is @ 3mm thick so the surface temp will be slightly less than the internal temp. However if I wrap the sensor onto the rubber hose with amalgamating tape, the sensor is effectively submerged into the rubber hose, and not exposed to the ambient air cooling it down. Should be good enough and plenty fast enough to indicate a developing issue. And I still have the over temp sensor/alarm indicators and I know they work. (2 new impellers please!)
1/8" NPT Female To M10x1.0 Male Reducer Oil Pressure Gauge Adapter Black https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.co.uk/ulk/itm/382268879272
:encouragement:
Can any electrical guru help me out here. My VDO gauges arrived and they need a Molex 334720801 connector. Great, an obsolete connector type but I managed to find some on American Fleabay.
I have no idea on how to wire the connector up. I am a purely analogue system. Which is positive, negative and signal wire(s). All my other guages only have these three and separate additional for dash light.
This is the only instruction on wiring:
This is the sender unit:
