HanSolo
New Member
Code:
Interesting comment this. I have to replace the totally knackered Paguro 3000 genny in my boat shortly. I am thinking of a DC genny and inverter as you describe. I have 660ah domestic battery bank, and would put in a hefty pure sine wave inverter.
The question I have is if I want to install a water maker, decent freezer and AC for a trip to warmer climes, is a DC system the way to go or am I better to stay with AC for this?
My thoughts on this are that you can get very adequate watermakers and freezers in 12volt, not sure about AC but big inverters are reasonably cheap.
the issue of battery charging is not so easy and big chartgers are not cheap. if you run the main engine for charging you have all sorts of other issues such as expensive servicing, reduced engine life through inefficient use (risk of glazing bores etc.). the engine on the Fischer Panda AGT 4000 is only 5.9hp and is rated to output 280 amps. The one i have is not in a case but about half the price of the one on ebay?
