Fire breaks out on 11mtr Motor Boat Dublin Bay ,
I know it's been said before, but I have seen a grp boat go up in flames and it was terrifying - and that was on a slipway were the owner easily jumped out. Can't imagine how scary it would be out at sea. Glad everyone was safe.
A ciggy on a cushion? Teatowel on a gas ring? Dont be rediculous, thats the stuff of B movies not real life.
You want to check out house fire stats - cooking appliances start most, cigarette fires kill most. Both perfectly possible on boats.
Then there are gas supplies and wiring subject to vibration, chargers, batteries, outboard fuel in lockers, etc, etc.
Lots of reasons for a fire other than the engine(s).
Kevin, we are not talking houses here. If some t**t was smoking on my boat he would go overboard, I wouldn't let him put his ashes on my cushion then wait till the whole thing was ablaze before calling the coast guard. C'mon. Your stats are not comparing apples with apples.
You asked how a diesel engined boat catches fire - Kevin gave you perfectly credible examples and you dismissed them as nonsense because YOU would never allow such things on YOUR boat - doesn’t mean it can’t happen. That’s without considering the engine (fires do happens), and diesel heater, electrics, etc. Really not that different to any other boat.
Not necessarily, a small electrical short will do it.
Again, does not need to be a major electrical problem.
I would classify it as a major electrical problem if my boat caught fire as a result of it, and so would Mrs SC35.
I've installed high-capacity fuses on my portable battery power sources (not boaty related) but that's not really feasible if the starter motor is pulling 450A on a normal start.
Watching what happens to a spanner short-circuited across a 12v battery is a bit scary.
Fine fuel mist onto something hot can also ruin your day.
No, that's a major problem, caused by a minor electrical problem ;)
That isn't a real problem, just fit fuses that can handle the current, with a good margin and use slow blow fuses.
Rubber spanners are the answer here ;)
Yep.
I would say from my research electrical fires are too often the culprits and there are lots of opportunities for one to start. Owner modified electrics, uninsulated conductors, stainless washers in the conductive path, faulty / overheating electrical devices. Purely speaking personally, my first port of call (excuse the pun) would be down the electrical road.
