ProDave
This came with our new boat. And like many things that came with it, it does not appear to work.
First attempt was try it at home. I have a 4A bench power supply so I tried it on that, set to 12V. If you try and extend or retract the rod manually, the voltage dips as the current drawn exceeds 4A.
Second attempt, take it to the boat and try it. The rod can be manually driven in and out, but it does not drive continuously while holding the button as I would expect, but it drives in bursts then stops until you release and press the button again. This may be normal behaviour not knowing this model?
Now try and get it to steer the boat and it just sent us off steering to starboard and not even trying to maintain a course.
Time to read the manual a bit more. There is a set up and calibration routine described in the manual, but that needs the boat to be motoring in a calm sea, it was not calm that day so could not try it.
But while reading the manual, I see it's rated power consumption, is 500mA when in "auto"
If that is the maximum, then clearly mine drawing over 4A to move the rod in or out is not right. Or is that 500mA average, given that when operating in auto, maintaining a course, the rod will only be moving in and out a short amount and not continuously.
So I guess my first question to anyone that has one of these is what is the real power consumption when driving the rod in or out?
Or to put it another way does mine look like something is seized up and needs unsiezing before I go any further?
