Fairline 43 Owners
Answers inserted in blue below Porto
Not coming across critical about the straight edge cut ends meeting just answering what I thought was a Mapish misunderstanding of Wake up query.
Jezz !
Agree with your sentiments re Itama fordeck s it’s matter of personal taste .
I don’t think in such a huge area it works aesthetically.
Some prefer a more modernist straight look like on this 62 ( Ferretti built ) ,
Although it’s solid planking and smells nice when new . Some a more busy trad look on this 48 hull ( same hull as mine btw ) .
Anything can be retro fitted .
Personally i prefer just plain white topsides and blue hulls none teak .Thinking ease of maintenance ( with a dog ) and cool under foot that’s all .Each to there own and I wouldn’t go as far a saying they are “ pos “
Beauty is in the eye of the beholder.:encouragement:
Cockpits as fore deck ,s and rear sun pad area are all crowded for the water run off .The cockpits have scuppers at the sides on the older Amarti versions .
Where I do disagree or you missed the point ? Is that good teak work and workmanship is not necessarily only found in super yachts or there’s a linear relationship with price and size .Hence the pic of that small boat .
The side decks I witnessed dealer fitted , prior to delivery on the FL 43 GT ( built by FL version 2 Co ) were thin veneers, sheets glued down and held 48 hrs with self tappers ....a kit maybe three sheets lengths per side and a triangular piece on the bow .
A few pics
Curves cut + king planks ......suspect artificial retro fit . Same hull as mine fwiw .
Bit too busy on the eyes all those curves a la JFM “. Gold std “
Modern Ferretti 62 solid teak deck ....note the fwd hatch position
Illustrating a crowned cockpit , There has to be a water flow to the sides and out .
I note from your post that someone is in breach of Data Protection Regs by providing information to 3rd parties & can therefore only assume that you are a dealer? We have been in contact with the CEO, Warranty Manager & agent and will congratulate them on trying to resolve the matter. The point of my original post was to try to HELP identify the source of the leak.
The first time the water came in, the rubbing strake was sealed, which appeared to solve the problem, however sadly not and the problem remained. Hopefully they have found the leak which they think was due to someone over drilling the fittings for the cockpit table leg. This still leaves us bewildered as this area doesn’t get wet! The good news is they also discovered & cured the issue of water entering the central engine room bilge.
As for your storm in a tea cup comment, had you had to wring out countless soaking wet towels from the bedroom over the last several weeks, and try to dry the wet bedroom carpet, to say nothing of the fabric and joinery which now need to be replaced, you might not make such a crass comment. I am amazed that, not having seen the boat, or spoken to the owner, you seem to be so well informed!
Has it got teak side decks ?
Remember I’ve seen them fitted .
The T43 factory side decks are not held down with self tappers, they are vacuum fitted.
You've seen one retrofit and we have no idea of the discussions or circumstances that led to the side deck teak being fitted that way. Using self tappers, is not uncommon 'out in the field' (not just for Fairline). Remember that the screws will take the glue through on the threads and it's all sealed with caulking so shouldn't leak.
However, I certainly agree that I wouldn't want any holes drilled into my boat for cosmetic reasons (teak side decks being a pretty stupid idea regardless).
There's only one reason why I could shell out 50k for the foredeck upon purchase of a brand new Itama 75, and that's for NOT having any teak at all.
Having said that, I would agree that straight planks "flow" better on a boat like that, aesthetically.
In fact, I would think it was a deliberate choice from the builder, rather than a cost cutting exercise.
After all, if they find folks willing to pay 50k for such a 100% fugly option, they could as well have made it a 70k option and make it 95% fugly.
Not to mention that if there's one think that can't be said of Ferretti, is that they lack good designers and/or the means for building a teak deck with curved planks...
Welcome to the information society. You don't seriously think that a paperwork effort like the GDPR will ever limit the fact that whenever you post anything on the web you give up your privacy, do you? :rolleyes:
Not my privacy, but the idea that someone seems to "know" so much about our situation then rubbished it is frankly unacceptable. My GDPR comment was that someone somewhere is sharing information outside of this forum without our agreement. Hopefully you can understand this.
Many on here are well connected with fairline.
You made a relatively damning post with little detail and then let the debate continue with little or no update.
People messaged you and got no reply.
So may I suggest you look at how you could have contributed to the debate as opposed to banging on about your gdpr rights. The forum is staggeringly helpful but only if you participate.
Indeed many people have tried to help HOWEVER if you look at my original post I was simply asking a question to try to help the Fairline technicians who were struggling to find the source of the leak. I have not been damning but on the contrary grateful for the attempts made. Not sure why you feel the need to be so aggressive? I think we should call a halt to this unproductive discussion between ourselves.
“I would be very grateful to hear from any 2019 Fairline 43 Open owners, either in the UK or abroad. We have experienced many issues which we are having extreme difficulty in getting resolved - are we alone in this?”
Nothing there about helping the fairline technicians.
Unfortunately, that's not entirely how your original post came across, Also, IMO, for a new / current model it's extremely unlikely that any owner(s) would have more knowledge than the dealer network. Combined with your lack of responses following your initial post will have led many of us to suspect you were just having a pop at Fairline.
Anyhow, it sounds like FL were genuinely trying to help and hopefully have got to the bottom of the issue. Hopefully you can put this behind you once they've fixed the damage and you can enjoy what I think is a great boat.
JFM, it was not meant as a criticism of your very finely specified boat. We have some badly laid oak flooring at home by the previous owner and I am now OCD about timber flooring and i notice joints and joint staggering on any kind of timber flooring wherever I go.
It makes complete sense in order to achieve your desired effect.
May I say thank you to all of those who posted their helpful comments and my apologies if I have not responded to everyone. Just to reiterate, at the time of my first post technicians had not visited the boat, although the agent had done their best we still had the issue. If another owner had had the same experience, my hope was that we could pass this on to the people working on our boat. To those who have chosen to be challenging, rude and unhelpful, may I thank you for opening my eyes to the pitfalls of asking for help on forums. Lesson learned.
That's certainly true P, but if he wanted to have a pop at FL, the explanation of what they did to troubleshoot the problem was much more effective than the OP, if you read it carefully:
1) "The first time the water came in, the rubbing strake was sealed, ..."
Huh? The rubbing strake is fitted above the hull to deck joint, and they didn't trust that to be waterproof? Seriously?
2) "Hopefully they have found the leak which they think was due to someone over drilling the fittings for the cockpit table leg"
Not what I would want to hear, if I were the owner.
Makes you wonder how many other over drilled holes there are elsewhere, which go unnoticed just because the water doesn't reach the interior, but is possibly damaging other parts, or is soaking some cored GRP internally - heaven forbid!...
I presume that's aimed at me. First point, Mr amateur lawyer, is that I don't (and don't want to) know your name/address/mobile phone/bank account/name of your boat or any other personal details, so there has been no GDPR breach. Second point is that your post speaks volumes about your character: you seem to be a clipboard wielding winghing jobsworthy type of guy who is trigger happy at claiming "GDPR breach alert!" (without understanding what it means). I bet it's a bunch of fun being the boat fixer assigned to working on your boat. You'll see from several other posts above that your protestations aren't landing too well with your audience. Anyway I hope the boat is fixed - happy sailing.
I'm not a boat dealer and have no idea why you would think that, but no matter.
