Boater On Thames
As mentioned above. I replace the small mechanical 8" puller legs with the 15 tons hydraulic puller. The result, the connection of the small leg broken, the shaft no movement at all.
The next step, I give up doing it myself, I will let the boatyard workshop try to see if they can remove it, if not, the only option would be to cut to split the coupling and replace it.
