richardsnowstar
Thanks for all the advice, I am learning a lot.
The water pump has drain slots to stop contamination and these appear to be only partly blocked.
The other concern is that the engine was smoking (seperate thread) before I noticed the emulsified oil so I am concerned now about the head gasket.
While sourcing replacement parts a very helpful supplier suggested removing the dipstick tube and using a larger suction tube with the vacuum pump. This seems like a very good idea that I thought I would share. I am sre this will help my problem extracting the oil.
The engine is raw water cooled.
Another suggestion I have had is to pressurize the water sytem with air (at low pressure) to see if this highlights the problem.
