RunAgroundHard
I have a 5mm thick stainless plate mounted at 45 degrees to a 5 mm thick stainless base plate, supported each side by welded gussets. The 45 degree plate is slightly undersized on length and the mounting holes for a foot block will be quite close to the edge. I can have my welder add two 20mm strips, one each side, full penetration welds, ground back flush to increase width by 40 mm. I can then mount the footblock, drill the 4 x M10 holes and fit washers and nylon nuts, all within the extended footprint of the 45 degree plate.
My concern is that the HAZ may cause the stainless to be more susceptible to cracks. The footblock sees a lot of force when hard on the wind, under full Genoa and staysail and if the sail flogs, can impart significant shock loads. Are there any other concerns? Should I just have a new pair of bases made to the correct dimensions?
Masthead rig, hence large overlapping genoa, 18mm sheets.
