Extending Europe's three month visa
Sahula
4 Jan 2011
I am an Australian cruising soon in Europe. The three month visa isn't long enough. I am seeking advice on the availability, process, cost, etc of applying for an extension. After cruising, I may winter in the Baltic, probably Finland.
Sahula
jimbaerselman
18 Apr 2006
Greece in Summer, Southampton in Winter
A few hints from the UK Cruising Association (www.cruising.org.uk)
First, your Schengen visa gives you any 90 days out of any 180 days, then you may apply for another visa. So you may be able to duck the issue.
Next, depending where you're spending your time in Europe, Croatia, Turkey, UK, the Channel Islands (a UK dependency) and Norway are all outside the Schengen zone (as are N Africa countries, not very quiet at the moment though!), so you can spend your other 90 days out of the 180 in one or more of these places.
However, for real ease of living, you should apply for an extended Schengen visa at an embassy of the country you intend to spend most time in. They will give you a list of possibilities applying to that country. Things do take time, however.
Talbot
23 Aug 2003
Brighton, UK
Next, depending where you're spending your time in Europe, Croatia, Turkey, UK, the Channel Islands (a UK dependency) and Norway are all outside the Schengen zone (as are N Africa countries.
Norway, Sweden, and Finland are all INSIDE the Schengen area.
tri39
25 Nov 2008
Sussex
Sahula
Are you taking your boat to winter in Finland!? There are warmer places. If you're arriving via the Red Sea you could even consider Israel.
There do seem to be huge no's of Aussies in the UK. They must know how to extend their stay.
maxi77
11 Nov 2007
Kingdom of Fife
The other problem to consider is how to extend your VAT free stay. An american who was moored close to us recently had to leave to avoid having to import his boat permanently into the EU.
