jcr
I have recently loaded up my yacht for a long trip and added self steering gear and a radar antenna to the stern. At hull speed, all vessels squat at the stern. I now find that my exhaust outlet (near the bottom of the transom) is fully underwater at hull speed. The exhaust system includes a water trap, anti-syphon and 18 inch gooseneck, which is fitted vertically. There is room under the sterndeck to raise the gooseneck by no more than 2 inches, which is not enough. There is not enough room to angle the gooseneck by any significant amount in order to further raise the outlet.
The problem is further compounded by the fact that my transom is at a negative angle of 45 degrees so that exhaust fumes and cooling water are well and truly trapped.
This must result in back pressure which will adversely affect the engine efficiency, if not engine life and reliability.
Any advice will be gratefully received.
