lustyd
But (you're still missing the point) if the prop on the petrol one can only put 1HP into the water because it's designed to avoid stalls at low speeds then it's completely moot, isn't it? If one motor can use all its power and the other can't then the ultimate power output of the unit is irrelevant, it's the in the water power that matters, and the ability to push the water backwards. There's more to speed than RPM when you're looking at prop design.Acceleration is of no consequence in a yacht tender, speed through the water when the revs have got up to max is. If you have a 15 minute trog out to the mooring, that is determined by the boats top speed, not whether it gats to maximum revs in 2 seconds or half a second. Once the petrol outboard is at max revs, a 3 hp motor will push it through the water faster than a 1 kW motor and hence shorten the time taken to get to the mooring - a real advantage. Who cares about the first 2 seconds of the trog?
