doug748
Buy the 40 quid saw, it will work till you know what you are doing and what you want. Keep your fingers out of the road.
So that's what I've been doing wrong. Still, it does save on combs and shampooCheap power tools invariably lead to ... bald patches on one’s head.
That's my philosophy when buying tools. I've bought numerous cheap ones over the years and still have most of them. A typical example was a big angle grinder that I bought in Aldidl (can't remember which) for less the £20 to cut slabs for a patio. I figured that if it lasted long enough to do the patio I'd have had my money's worth. 20 years and a couple of full house and garden refurbishments later, it's still going. Aldidl tools generally seem to be decent DIY quality. If I use one enough to wear it out, then it's time to buy DeWalt or similar.Buy the 40 quid saw, it will work till you know what you are doing and what you want. Keep your fingers out of the road.
I would still suggest that he buys a cheap track saw to that end I found these videos
B&Q had a deal on the Ryobi circular saw a couple of weeks age. They might have the offer still on. I would have bought one but had just got the Parkside 20v one.I have nothing constructive to add to this, but would just like to say thanks to the contributors. We have some interior work planned this winter and has started looking at table saws & circular saws. The advice above has helped me greatly.
I may get chastised for this, but i'm a Ryobi One+ tools guy - I only "tinker" with woodwork so the quality seems fine for my basic needs, the cost is about right and they have a huge range for all areas that uses the same batteries. I have lights, garden tools, drills, drivers, etc.
Nothing much wrong with the cheap saws, the problem is they usually come with a couple of very short tracks and some don't fit long tracks of other makes.
I have never ever regretted buying top end power tools ( when I could haha )
Otoh the nastiest noisiest tool I ever threw away was a Macalluster pad sander . Bought only because the switch died on my good ‘un and it was what was available on that day in that place . £40 pished away really . Man , vibration and howling noise ugh
Otoh 2. Lidl inexpensive tools seem to be a ahem cut above , pound for pound and the warranty is good
For what it’s worth I have TWO DeW compound saws on a bench with different blades and a DeW 71/4 for panel sawing ..just do the job without fuss or faff
I would say , to the OP, since he is asking us to decide , buy Lidl AND
Makita !
And make one of them a bench compound mitre saw ?
And grab a spare discarded cyclone vacuum cleaner to take care of the dust ?
Gone off DeWalt after looking inside a drill that conked just out of warranty. Cheaply done and nothing like as good as my older angle grinder. I also have an older B&D two speed drill that is Italian. Their label is on one side and B&D's on the other. Brute of a tool with wristbreaking torque. Had it for 40yrs I just realised..I concur
If one is lucky enough to have a sense of what is ok then some of the design and spec on value range tooling is perfectly acceptable .
The knack is to know what is just frustrating tat, or as the OP, to ask of those who have ventured before ..
I have seen Black and Decker power planes in boatyard daily abuse which refused to die ! Albeit they did cry out each day ?
Talking of hand saws, I do like the Japanese style draw saws, they seem to easily produce a straight line cut with very little effort.Sometimes you're better off with an £8 handsaw...
