Engine Service Intervals
The air filter element looks exactly like the filters on the outside of con saws..I doubt you can't find similar if you had one of these in your hand.
The water separator/fuel filters and oil filters are all available readily from HiFi.
HiFi SN25098 Pre-Fuel Filter
Repower marine UK do the impeller equivalent, for about 24quid..Pardon our interruption...
The belt is surely available from gates or Continental if you have the measurements.
Anodeoutlet.co.uk have a full kit of anodes and brass caps for 77quid..
KITYANMAR - Yanmar 6LP/6LY/4LH Zinc Pencil Anode Kit 119773-92600
I reckon you can do the job for around 200quid using parts that are used all day long in hard worked machines (including on yanmar machines)
20 liters of 15w40 shouldn't cost more than 100 quid, it's a normal oil in simple trucks and machines..
I am using HiFi filters in my CAT digger at the moment recommended by a company that supply stuff to guys who are working machines hard for weeks on end and would soon come back if they were causing problems, afaik they are made in France.
I spent a few moments searching your part numbers.
The links find alternatives (many for some parts); you then have to check pricing and availability + shipping to you
Air filter cross reference
Fuel filter cross reference
Oil filter cross reference
Impeller cross refs:
Jabsco 31130-0061​
Kashiyama SP-130​
Yanmar 119593-42200​
Yanmar 119593-42202​
JMP 7420-01​
Mercruiser 47-831311350​
CEF Impeller 500161​
DJ 09-42-1001​
AØ: 65 mm​
B : 68 mm​
CØ: 15.8 mm​
No. of blades: 10​
Impeller pump O-ring is included in impeller kits but also can be found by Googeling 24321-000700 alternative
BELT, V-RIBBED #119798-77350 - Vmarine
Yanmar 119574-18790 Zinc Pencil Anode (16mm dia x 51mm) (ASZ1452)
Thank you. Jones of Nenagh won't let me access their site, which I assume is because of my Turkish ip - this is a common problem here accessing UK and Ireland websites. I'll try again later with a vpn. Those anodes are for 6LY engines, mine are 8LV. I'll check some of the other links from other posters.
The links find alternatives (many for some parts); you then have to check pricing and availability + shipping to yous
Thanks. I think the arthritis has spread to my brain. I was trying to do this on the phone and obviously making a hames of it. It worked when I did it on the laptop.
Hey - get yourself a VPN to use for security, disguise your IP or (seem to) be located where you desire (tell the VPN where to route you out on the web).
Select VPN provider with care - freebees tend to have a hidden agenda ;)
The brass caps are reusable and in most cases the old pencil anode can be unscrewed or dug out of the cap. Once you have built up a stock of 'old' caps, the pencil anodes can be ordered separately at a huge cost saving. In some cases the old anode can't be extracted from the cap because the anode has virtually wasted away, which is why you need a stock of empty caps.
I use Nord VPN but the authorities here are actively blocking VPN's. The VPN opens but you can't connect to the net. There's a workaround but you need to have access to WiFi and mobile data to use it.
Those anode guys have many zinc engine anodes it's really a case of identifying one which fits. Probably does not matter if it is slightly shorter or more slender once it fits into a new or reused cap...and you can keep an eye on its performance...
