Refueler
More likely a fouled hull, leaking injector or similar
Guy has gone from 8kts to 4kts ...... that's one hell of a drop for a fouled hull ......
Fair comment, but I was referring to the exhaust elbow where the cooling water enters the exhaust system. Perhaps i should have made that clear.
From the OP's post it would suggest something more "sudden" that is why I suggest that if the boat has been left, then fouling could ( Note- Could) be the problem. He returned to the boat & noticed a marked difference in engine & boat performance. Not a gradual one. Refueller's picture demonstrates what I was suggesting: But it is only a suggestion. Time will tell.
Mine's on the prop! £1?My bet would be on a partially blocked exhaust elbow, as your symptoms are exactly as I experienced when mine was blocked a few years ago.
See post #28Get a diver to clear it?
I an 73 years old & i dived under my boat to remove a net from my saildrive when in Middleburgh. The boat was on the pontoon.
I wore a shortie wetsuit and a pair of goggles. A shortie wetsuit is cheap & I keep one aboard. A full length oneis not necessary but protects the skin. (handy if you have to partially beach the boat on a sandy shore to do it & have to wade in water) Some flippers would have been handy. I did keep floating up, so I have now purchased a weight belt with a quick release buckle to help me get down quickly. Then release it to come up quick.
I did not have a rope to pull me up, but I do have ropes suspended each side of the boat to pull me along. All you need to do is get between boat & pontoon opposite the saildrive with the crew holding the boat 3 feet off (I was on my own so only had 18 inches) then using the pontoon, invert yourself & give a good push from the pontoon to get down. You should be able to hold your breath for 1 minute which is more than enough to see the prop. I had to get within 18 inches to see it.
I managed to get the net off easily. But if you get to the prop you can have a look then you will know if it is OK. Then you can decide if it is worth paying a diver, or having a liftout. You might manage it yourself with a bread knife if it is rope.
I am not fit by any means & cannot swim the length of the boat so used ropes suspended along the side to work my way along the hull to the pontoon steps. If you have a crew to help it will be easy enough. The experience is worth it.
You could ground the boat very near LW. so it does not go right over but is in 5-6 ft of water where you can stand on the bottom, then nip over & have a look.
It's a sail drive so not possible.Have you managed to find out whether the prop will turn freely by hand yet?
