ProDave
That suggests your batteries are flat. Highly unlikely ALL of them.UPDATE
Shorting out the solenoid with a screwdriver did not do anything.
There is only 7.15V at the big red wire on the solenoid and the same voltage at the red/white terminal on the key switch. (This is testing it with a multimeter with the - ve lead earthed on the engine block)
The voltage is the same on the engine start battery, on the domestic batteries or on both (I have a 1/2/All switch)
Where should I look next?
(All other electrics, lights, instruments, Webasto) are working fine)
So repeat your measurments with the -ve probe of the multimeter on the battery -ve terminal.
Also measure on ohms between battery -ve terminal and any metal part on the engine block.
Report the findings.
