Engine mounts
Clypsie'sDream
27 May 2019
I’d be interested in any yacht owners experience with ‘Sole’ Spanish engine mounts ?
I have a Volvo MD30 installed in my 44ft shaft drive aluminum boat. Volvo mounts x 4 are £1200 ! Sole are half price but will they last ?
peteK
4 May 2009
Wirral
Av online marine engine mounts is another one but appear to be the same as the Parts4engines mounts.
Refueler
13 Sep 2008
Far away from hooray henrys
Are Vetus mounts still out there ?
The guy who fitted the 4-99 to my 25 originally - used Mini Petter mounts ... YES ! Mounts designed for a 12hp ... the 4-99 was 39hp. Not only that - but set the bolts UP through the oak bearers - then bolted to engine - then lsid whole lot into place .... lined it up and fixed. When 25yrs later they failed ... YES - they lasted that long - we had to hack the mounts out with the engine as there was only about 1" clearance under the oak bearers ...
The replacements were angle iron bearers - so bolts could be got at and serviced ... Vetus mounts used .....
Few years later when the 4-99 seized and was replaced by the 4-107 (a drop in fit) - the same Vetus mounts were still perfect and used. Many years later - still good ....
