Engine Mounts
mulligan
25 Oct 2001
Lincolnshire
I have found out that they are Halyard Marine Aquadrive engine mounts. Could anyone tell me of a good alternative to my current Aquadrive mounts, I am looking at something which is will stand the test of time!
Regards
dickh
8 Feb 2002
Suffolk
Metalastik Cushyfloat anti-vibration mounts are now marketed by:-
Trelleborg AVS, PO Box 98, Evington Valley Road,
Leicester LE5 5LY. Tel 0116 273 0281 Fax 0116 273 5698
Go direct, I have just bought 4 mounts for my Perkins Perama M20 for £25.89 ea. including VAT & P&P - I was quoted over £60 each from a Perkins agent... Trelleborg can offer them as Marine mounts with the stud and nuts for about £38 each, but I bought the standard Industrial type and re-fitted the existing studs & nuts onto the new mounts.
For information, the mounts were No. 17-1600-55 (55 being the Shore rubber hardness).
I also notice that Vetus sell mounts which look remarkably like the Metalastik/Trelleborg type at a similar price but this would have to be checked.
Heckler
24 Feb 2003
Have been doing my research as well, 7 years on! Volvo Penta MD22 is a Metalastik Cushyfloat with 45 stamped on the base plate which signifies a Shore Hardness of 45. Roys D22-55 Volvo Penta is the same. Will bell them tomoz to see how much they are now!
D2 - 55 part number = 846765
MD22 = 846765
Have used www.marinepartseurope.com to check the part numbers, I know the VP2030 engine mounts look the same but the part numbers are different. I would suggest to any VP20X0 engine owners to check the number stamped on the base pate and work out which one it is from this and the bolt centre measurement
Stu
29 Mar 2010
I work for a company called AV Industrial Products Ltd who specialise in Anti Vibration Mount, including a range of Marine Engine Mounts. They are based in Leicester the same as Metalastik and offer an equivalent range to Metalastik. One of the posts above mentioned Metalastik 17-1600 for around £30. AV Industrial Products identical product would be at least 50% cheaper.
Their website is www.avindustrialproducts.co.uk , or email address mail@avindustrialproducts.co.uk
Hope this helps andbody who is trying to find a reliable supply for your mounts
Heckler
24 Feb 2003
I did all this a few months ago and posted it, I found that the Vetus ones looked similar to mine but they didnt do a 45 shore hardness, I then found out that Robush are the main dealers for Trelleborg and sell them for a similar amount, one point to watch, as standard they have coarse thread and if your Volvo has fine threads you have to specify as such OR do as I did and recut the Volvo threads.
Stu
