Kwik Decision
Maybe fit an exhaust temperature alarm or piddler tube in front of the helms view?
If you get a water inlet blockage/failed impeller then in theory by the time the engine overheat alarm goes off, plastic water mufflers, water hoses, exhaust hose ‘ might’ be a bit cooked.
Excellent suggestion. I fitted one of these on our boat a few years ago, and thoroughly recommend them:
Shop
I've witnessed the aftermath of cooling water failure without such an alarm. By the time the engine overheat alarm went off, a hole had been melted in the plastic silencer box. The blockage was quickly removed, and the engine re-started, only for the bilge alarm to go off a couple of minutes later...
