engine diagnosis
snowleopard
Oxford
'my engine overheats if i do more than 4 knots' is all the clues i have though i do know that it's a fairly new engine.
once i've checked for impeller problems and blockages in the raw water circuit, what checks should i be making?
boatmike
30 Jun 2002
Solent
Is the engine properly aligned on its bearers? Does the engine reach peak revs easily when a) in gear b) out of gear? Does the propshaft freely rotate when disengaged? Is your overheating combined with smoke from the exhaust? Do you have the correct oil at the right levels in both engine and gearbox?
boatmike
30 Jun 2002
Solent
Good point! Check thermostat! (Take it out and boil it up in a saucepan to see if it opens)
gtmoore
8 Jan 2002
Croydon
Definitely check the raw water inlet skin fitting. I've just helped a friend scrub his boat off who was having the same problem and the grating was virtually completely blocked with encrusted worm type fouling. I'm surprised his engine wasn't overheating at tickover!
<hr width=100% size=1><font color=blue>Gavin </font color=blue>
Evadne
27 Feb 2003
Hampshire, UK
Not just the skin, but the pipe too. Barnacle lavae are small enough to swim through any grating that may be fitted ... I found one when I closed then opened the gate valve (yes, I know,) and heard a crunching noise. Lots more cooling water after that one though.
snowleopard
Oxford
definitely not over-propped as this is a new problem.
i have raw-water cooled engines on snow leopard so not familiar with heat exchangers. what can i check on the fresh water side apart from coolant level?
Paragon
25 Oct 2001
Plymouth
Hi Chris
Given your mooring location, I'd be tempted to look at the heat exchangers themselves as they have become silted up so are working to some degree but not enough when over 4 knots (good fishing speed I recall!) Whilst I have not personally done it the unit (heat exchanger) should be removeable and some sort of end cap comes off to flush the thing through (just going on a piccy I've seen of another engine, not sure how your Yanmars are set up) I understand that this may even be an annual service job.
Anyway, that's my t'pennyworth!
Regards
John
Nauti Fox
28 Oct 2003
Kent
www.facebook.com
Can you check the raw water strainer with the engine running?If there is an air gap at the top it may be as other posters have said fouled skin fittings.Got that on one of my engines at the moment.
<hr width=100% size=1>No dear,the water goes in the other one.
snowleopard
Oxford
no john - the problem is on a friend's boat. mine is safely ashore now. hope to get more information about the motor sometime today.
oldharry
30 May 2001
If the engines are running normally otherwise - no smoke, starting etc, then almost certainly the problem is in the raw water cooling system. The fresh water cooler is like the one in the car - as long as there is water in it to the correct level and there are no leaks it will be OK.
The seawter side is another matter altogether, with all the mud, crud barnacles etc going through it, something has blocked somewhere: inlet fitting, strainer, pump impellor, heat exchanger can all clog up and cause overheating problems. I once had a hot running BMC, everything checked out fine - over and over again! Eventually we found a bit of rubbish had been drawn in and had stuck at the joint fitting of the outlet side of the pump. With the pipe disconnected there was ample water flow, connect it up and it reduced to a trickle - except you could no longer see it!
<hr width=100% size=1><P ID="edit"><FONT SIZE=-1>Edited by oldharry on 21/10/2004 13:34 (server time).</FONT></P>
maxi
8 Nov 2002
Hampshire
Check out the raw water inlet pipe - these can delaminate internally and close themselves off whilst on-suction - similarly, if there is a bend in the pipe or any distortion, it is common for the pipe to be sucked flat as suction increases but appear normal with the engine stopped.
Try replacing the inlet pipe as a very cheap first step, or at least try a temporary replacement just to prove where the problem is, or isn't.,
Keith
9 Dec 2003
andros bahamas
I know it sounds stupid (but it happened to me) have you checked the v belt tension, my 2GM did the same and at low revs it was fine, at higher revs the belt would slip, after all they are weedy little belts, changing to toothed belts helps longevity.........keith
snowleopard
Oxford
stop press - more info
i've been in touch with the owner and got some more info-
the engine is an Alpha 40 (never heard of it, have you?)
it has a hydraulic drive and, wait for it, the raw water passes through the hydraulic oil cooler before the engine heat exchanger. in the past it has been ok up to about 5.5 knots but now overheats at 4 knots. the volume of water passing through the calorifier coils is good and the water in the calorifier gets v. hot. the heat exchanger has been checked and the flow is ok.
sounds like it's a raw water problem. a higher-lift cam has been fitted to the raw water pump in the hope of increasing the volume but limited success.
anabel
14 Feb 2003
Shannon Estuary, S. Ireland
If you have tried all the very sensible suggestions mentioned so far you and still no joy , you might consider the soundproofing. A couple of years ago I had problem with engine overheating at high revs. The problem was the soundproofing. I had improved (!) this so much that the engine compartment was almost airproof. Consequently the air being drawn into the engine via the air-intake was getting hotter and hotter which inturn caused the engine to get hotter which in turn caused the temperature of the air being drawn in to get hotter and so on. Cured same by attaching exhaust type tube to air intake filter unit & leading it into the end of the quarter berth. This solved the problem.
