Engine Anti Syphon Plumbing Check...
mattnj
26 Jul 2007
www.red-data.co.uk
me again :)
I didn't take any photos before I removed engine, so i cant remember but I think the raw water originally went:-
seacock -> strainer > pump > gearbox > syphon valve > heat exchanger (then to elbow)
I have removed the raw water gearbox cooling bit so should it now be:-
seacock -> strainer > pump > syphon valve > heat exchanger (then to elbow)
Thought I had better check that's the way it should be routed..?
VicS
13 Jul 2002
MD 2020 ?
Originally it went seacock > strainer > gearbox cooler > pump > anti-syphon valve > heat exchanger
See the pictures in your owners manual
mattnj
26 Jul 2007
www.red-data.co.uk
MD 2020 ?
Thanks, it was an md2020, I've replaced with a Perkins 400, which is the same thing pretty much, and also the same (more or less) as the D1-20
bit of a mash up :)
Plum
6 Jun 2001
UK East Coast
me again :)
The anti syphon valve can be before or after the heat exchanger, just ensure you have the shortest/smoothest hose run and the valve is more than the specified minimum above water level (usually 400mm)
Www.solocoastalsailing.co.uk
