saltyrob
Hi Folks,
Have fitted a new cutless bearing and checking engine alignment . Do you do the height of engine first and then the horizontal alignment. Have found it tricky to adjust horizontal alignment before and note that the engine mounts are fixed to a plate
with a hole at one end and slot at other through which the bolts go into the engine bed. Should the hole /slots be positioned in a certain orientation to allow horizontal adjustment . Have tried figuring out on paper but would be grateful for any advise.
Many thanks
Rob
Many thanks
Rob
