vas
OK, title is trying to describe the issue, obvs not enough, so bear with me.
mobo is twin screw on shafts, hull is plywood on iroco frames, built in 74-75, 24V.
Existing el.panel restored, lots of useless wiring removed, working fine (he says!)
All through-hulls are GRP (Tru-design).
Boat is NEVER on shore power as I need to run 100m+ cables from nearest pillar and I don't like that, and I don't need that with 600W solar in the med.
There's a new (well new when rebuilt was done in 2015) reasonably thick tinned ground cable doing a loop from:
battery negative (4X6V Trojan T-105RE bats are just aft of port engine)
port engine block
port shaft seal (bronze)
port p-bracket (bronze)
port rudder (bronze)
port transom 1kg anode
stbrd transom 1kg anode
stbrd rudder (bronze)
stbrd p-bracket (bronze)
stbrd shaft seal (bronze)
stbrd engine block
There's obvs an even thicker (thumb thickness!) neg connection between blocks and neg battery which also goes to generator block (aft of stbrd engine)
Multiplus II 3000/24 is just aft of port engine and batteries wired with short massive cables to the batteries through a Victron BMV700.
There's also a raspberry-pi running VenusOS v3.0 and a Victron 100/30 MPPT controller from two serial wired 1X2m 300W panels with OV of circa 48V ea)
Finally since last season I've got a custom built 8S EVE 304Ah lifepo4 bank, with dedicated T-class fuse, it's own current monitor and bms (diyBMS - opensource) and a BlueSea contactor.
All the Victron stuff and the diyBMS are wired and communicating nicely together with bms instructing charge/discharge profile to Multi II and MPPT.
Amazing as it may seem, all works fine and I've got ample power to do whatever I want onboard. OK, took a couple of lockdowns to finalise the lifepo4 conversion, but the result is what counts
Now, following this long intro, into the Q.
When Multi is working charging mobiles, running laptops and doing silly low amp stuff, all's fine, however when I run largish tools or even worse when I run the 1800W watermaker (via an inverter through a 3phase motor to enable soft start and save the membranes) I get some serious EMF.
i can see that on my various arduino like boards (teensy to be exact) which are monitoring various engine/tanks/weather/etc states and converts them into the NMEA2000 network so that I can view data from anywhere onboard.
So a 20% fuel may start fluctuating form 15 to 25 for the duration of the high amp draw operation.
N2K bus takes it's power from the stock el.panel from the lower helm, same as all other devices.
If I run the generator (8kva) which tbh have no reason anymore to do so, and Multi is in passthrough mode, things are much better.
From my understanding this is a case of grounding issue for the multiplus and here is my Q:
what/how do I do it?
Option 1 (which I'm doing right now) is discard measurements for whichever duration of inverter is loaded... OK, works, but doesn't feel right tbh.
Option 2 is to most likely ground the Multi II case. Went through some Victron docs it's a bit confusing and looks like the only realistic solution would be to wire the case to the cable looping all metalwork at sea. I have no extra isolating "plate" in the water as some newer craft have and wont be able to do it before next season lift.
Option 3 is to ground the Multi II to the bat negative (which is more or less the same as Option2 tbh).
Not sure if #2 or #3 is going to be worse for ground loops...
suggestions please before I start testing next week that I'll be onboard!
and please don't need anyone to tell me my system is too complicated and I shouldn't have it like that, cause it's really pointless and not what I'm asking...
cheers
V.
port engine block
stbrd engine block
cheers
V.
