Electrical Questions
Cheeky Girl
23 Feb 2004
Stirling, Scotland
Hi
2 questions
1. I have two of these fuses bedside the batteries. Do they ever blow and if so should I have a spare?
2. I assume the blue box is splitting the charge between the 2 banks of batteries as it an original (2004) should I replaced it with something more modern ?
PaulRainbow
16 May 2016
Suffolk
Hi
2 questions
1) Hard to see what they are protecting, but it would be prudent to have a couple of spares onboard.
2) It's a split charge diode. It is connected to the alternator output and then to the different battery banks. If it needed replacing i'd fit something better/more modern, but if it isn't broken there's no rush to replace it.
Cheeky Girl
23 Feb 2004
Stirling, Scotland
Hi Paul
The fuses are connected to the batteries then to the isolator switches then the control panel. I haven't seen fuses like these so where could I get a spare?
How would I know if the diode needs replacing ?
Regards
Graham
PaulRainbow
16 May 2016
Suffolk
Hi Paul
Regards
Graham
OK, so battery fuses then. They are industrial fuses, take a picture of the mo0del numbers etc and look them upon the internet.
Normal failure mode of the diode is that one or more batteries don't get charged.
KompetentKrew
27 May 2018
My local electrical factor has them.
I have a single fuse like this on my boat, and corrosion on it and its holder (probably 25 years old) were the source of a voltage drop under heavy loads.
Cheeky Girl
23 Feb 2004
Stirling, Scotland
Looking at the fuses there is a fair bit of green around so will prob remove and clean up the terminals terminal befor eany issues.
They are 20 years old now
KompetentKrew
27 May 2018
My recollection is that it was easy to polish up the legs of the fuse itself with emery paper, but not the inside of the holder.
Neither fuse nor holder were expensive to replace, but I wouldn't bother if you're having no issues.
The only reason it was a problem for me was that my inverter would show a low voltage alert and refuse to work under moderate load - i.e. I believe the corrosion on the contacts was causing resistance and thus the voltage at the inverter was lower than it was at the batteries. Replacing the fuse and holder fixed it.
