electric advice please
deep denial
10 Mar 2006
Southampton
My 100w solar panel isn't charging, and I was told that it was now u/s and needed replacing - it is quite old. However on testing it shows 12.8v coming from the panel, but 0 v coming from the charge controller. Does this mean that it is the controller which is at fault, or could it be that the charge from the panel is too weak to get through the controller? Thanks in advance
Might be able to couple this aged panel up to a car cigar plug/usb adaptor and us it to charge devices .
Are you measuring panel voltage with the panel disconnected from the controller? If so, 12v panel should be giving 20v+ in sunlight.
In bright sun light the open circuit ( that is not connected to anything ) voltage of a "12 volt" panel should be in the low 20s (21, 22 or 23 ........something like that )
If you connect your multimeter, set to its 10amp range, directly across the panel you should see something around 5 amps or a little more , in full sun.
