geem
The secret of moisture removal in a boat is the introduction of outside air heated up to room condition. Air at zero degC can be 100% saturated but heat it to 20degC and its RH drops to 26%.. It then has the ability to absorb moisture. It may be counter intuitive but you need outside air on a cold wet day. Whether you choose to heat the boat by drip feed oil heater, radiators or ducted air you probably need more ventilation than you think. The advantage of a radiant heat source like a drip feed heater is they are hot and you get lots of radiation that heats up the surfaces of the cabin. This creates warm surfaces. Combined with an open hatch a crack they work well. The air can be a little cooler as the surfaces are warm. This is not so good with warm air heating as the surfaces stay a little cooler any your warm air escapes when you open the hatch. I like drip feed heaters as you use so little power.Agree that ducted warm air systems are quick to deliver heat, a lot quicker that the waste heat from a generator started from cold.
The other benefit of the hot air eberspacher type heaters is that the hot air is from outside the cabin which forces out the moisture laden air and so reduces the condensation in the cabin. A wet system with radiators would heat the existing moist air in the cabin so you may get more condensation on cold surfaces.
Colin. Www.solocoastalsailing.co.uk
