RunAgroundHard
The cables have been cut with about a foot tail left. Can these be extended using an appropriate connector? Considering buying g a second hand unit for a good price.
IIRC the cable entrance into the antenna is sealed.
The cable is a normal three strands electrical cable, not even shielded.
My antenna is on the stern gantry, about 4m asl, it picks up other radars at about 15-16nm distance; the beeper is sufficiently loud to wake me up. I then check on ais/radar what the other ship is doing. Green led are usually fishing or smaller m/vessels, amber led is S band and usually the big boys.Thanks Roberto and Jamie N. I think adjusting the cable lengths is a reasonable option. I am considering mounting at my mast head and would rather a continuous cable to the control box. However, having read the instructions, it suggests that mast height may activate the unit from radars that are too far away ie frequent trips. The seller stated it was removed from a stern rail.
I have had the dual band for some years but never have the alarm on as I sail in a busy area. switch is below so being on deck i never watch it. However, your comment above raises my interest. I have a switch plus a light next to it. I have never worked out what why to flick the switch for on or off. & I think I have been sailing with it turned off for a few years. I certainly have the alarm off as it bleeps continuously. But that aside, are you saying that the light changes colour or does your version have 2 different lights?My antenna is on the stern gantry, about 4m asl, it picks up other radars at about 15-16nm distance; the beeper is sufficiently loud to wake me up. I then check on ais/radar what the other ship is doing. Green led are usually fishing or smaller m/vessels, amber led is S band and usually the big boys.
You will also be able to check the number of ships having their radar on and not their AIS and form your personal opinion about the latter.
I'd be concerned about mounting the transponder low down. More than 75% of the benefit to me is some security that my boat is providing a good & reliable radar return when scanned. At 4m in ocean swell, I'd be concerned that wasnt happening.My antenna is on the stern gantry, about 4m asl, it picks up other radars at about 15-16nm distance; the beeper is sufficiently loud to wake me up. I then check on ais/radar what the other ship is doing. Green led are usually fishing or smaller m/vessels, amber led is S band and usually the big boys.
There are three separate leds (at least on mine): the green one flickers when hit by a X-band radar, the amber one when hit by a S-band radar, the red one when instrument turned on. Two switches: one instrument on/off, the other buzzer on/off.I have had the dual band for some years but never have the alarm on as I sail in a busy area. switch is below so being on deck i never watch it. However, your comment above raises my interest. I have a switch plus a light next to it. I have never worked out what why to flick the switch for on or off. & I think I have been sailing with it turned off for a few years. I certainly have the alarm off as it bleeps continuously. But that aside, are you saying that the light changes colour or does your version have 2 different lights?
I think there is a trade-off between two aspects.I'd be concerned about mounting the transponder low down. More than 75% of the benefit to me is some security that my boat is providing a good & reliable radar return when scanned. At 4m in ocean swell, I'd be concerned that wasnt happening.
I will nipback o the boat in a couple of days & check again as to what I have. If OK with you I may come back to youThere are three separate leds (at least on mine): the green one flickers when hit by a X-band radar, the amber one when hit by a S-band radar, the red one when instrument turned on. Two switches: one instrument on/off, the other buzzer on/off.
A video I posted on the other thread about the same subject, you can see the three leds, the green one is being activated by my own radar, the amber by the ship X-band radar at about 12nm distance, the ship is not transmitting AIS (which unforunately happens more than one is led to believe).
