Eberspacher
moodycruiser
14 May 2004
Solent
www.pctony.co.uk
Anyone got any ideas or come across the following problem on a DL3.
When the main switch is set to vent I can hear the fan going a good'un, and it keeps going till I switch it orf. When I switch to Heat - nada, zip, nothing, no noise, zero. What size hammer ???
<hr width=100% size=1>Tony
Talbot
23 Aug 2003
Brighton, UK
You might find the answer if you download the <A target="_blank" HREF=http://www.espar.com/htm/tecmans.htm>technical manual</A>
Chris_P
1 Jun 2004
Might be worth checking the battery volts. When volts are low our Eberspacher just sits there doing nothing while the control panel looks ok
VicMallows
25 Nov 2003
Emsworth, Chichester Hbr, UK
Another possibility is that the 'up to temperature' (flame established) sensor (an on-off thermostat) has failed open. Note this is NOT the overheat sensor which can be reset. This gives the symptoms you describe.
Vic
andyball
1 Jun 2001
If nothing at all happens, suspect the switch + associated wiring or the control unit.
As I understand it, when switched to heat, the fan should run first before there's any attempt to ignite.
