NZ Watcher
1st Post - thanks in advance for any help
I have a new D4 - I added the 7 day timer and also a remote external Temp Sensor.
At present the Heaters air intake is drawing from outside (night time temps at moment around 9-16c)
I do intend relocating it so the air will be drawn from inside batch.
Can someone direct me to how this remote Temp should be wired up.
I seem to remember reading somewhere that disconnecting an internal Temp sensor should be done ??
Is this true and if yes - how do you do it.
At moment - I have it wired to the "grey" wire only. It seems to be less reliable when connected to the "brown/white" as well.
Again - thanks for any assist
