alanducker
I have a D3L unit which has failed to start after not being used since last season.
When the control switch is turned to cold operation the fan works continuously.
When turned to full or half heat modes the fan worked for about ten seconds then stopped. The burner did not get to the stage of firing.
To make matters worse after checking fuses and connections and finding it still did not work, I accidentally left the switch turned to full heat mode for several hours. Now the fan does not even work for the ten seconds. It does still work on cold mode however.
The battery voltage (at the batteries) is OK but just in case I tried starting the heater with the engine running at about 2 000 rpm, but again the heater would not work.
Although I think the problem is electrical I did check the clear plastic fuel line to make sure there are no air locks.
Can anyone offer advice on what could be wrong and what to do.
Alternatively can anyone recommend an engineer who understands these things in the Poole area.
