colhel
I've done this a few times in a sailing boat but this will be our first time in a motor boat.
Nimbus 3003 with single Tamd41a.
Jobs completed this Winter, new oil and filters ,fuel filters, cooling issue sorted to the best of my knowledge anyway ie, can run at WOT for a long period of time and temperature gauge doesn't go above 90., the exhaust elbow and intercooler don't get overly hot and I'm not loosing any coolant from the fresh water system.The unusual rubbing noise has gone since I tightened the allen bolts on the clamp that grips the prop shaft.
I'm having her lifted and scrubbed at Portland, where I'll be fitting a new arbour for the rope cutter.
So, come Friday the plan is to leave Weymouth about 5.30am to catch the East going tide into Cherbourg, we will be cruising about 12-15 knots depending on comfort and conditions so a bit of help from the tide will be welcome, probably. On Sunday we'll head over to Alderney to meet some friends on their sailing boat and then down to Guernsey with the possibility of a bit more exploring and then heading back to our home berth at East Cowes Marina.
This isn't only our first motor boat but our first boat with a proper fridge, battery charger and hot water, I haven't seen a polarity check light on board. Should I reverse the wires in the shore power socket (IF) we decide to connect up? the batteries shouldn't need re-charging so I'll just switch the charger off.
Any other tips most welcome!!!
