WoodyP
I nearly made a sensible reply until I checked the date.
When you say 'lost' do you mean drifted away or............?Their's nothing like a blast from the past!
All those, now lost, contributers ☹
I always use Gates belts, the Cogged Raw Edge belts which transmits more horse power than a standard vee belt which I fitted to my last boat, a 19hp Perkins but my current boat has a multi-vee belt which has lasted 14 years. I did replace it last year but that's another story... They must be tensioned correctly though.
Your advice is 19 years too late!
I wondered what had happened to Snowy. He gave me good advice before my travels.Exactly my thought when I saw Snowleopard.
YesWhen you say 'lost' do you mean drifted away?
I understand the reasons for belt dust that you and others have provided, and remedies for avoiding it. What I really need to know is the best way to clean it off the engine, the inside of the engine insulation and out of the bilge beneath the engine.The thread is old, but most of the suggestions are still valid, should the OP or anyone else be suffering from the problem.
Other causes I don't think have been mentioned are -
a) some engines (no names, no pack drill!) were supplied with undersized belts for the loads they had to drive, and so they tend to scrub and dispense dust (note also the loads placed on alternators have generally increased over the years, exacerbating the problem). The solution there is to replace the pulleys and belt with something beefier, or just live with it; and
b) if the engine compartment is (regularly) too hot it results in belt dust.
