VicS
No viable recoil starter for that model, although Siba did make one in period it was a real heath robinson affair and not really needed.
I assumed that was a misprunt and he meant recall.
I managed to persuade my '65 featherweight (somewhat of a misnomer) to run well on 20/1, it didn't like 25/1 even with the replacement needle. Tremendous saving on oil costs and also reduced pollution (Dylan please note if you're watching).Nothing to worry about. That is just unburnt oil residue because the engine should be running on 10:1 mixture. You may find it is reduced if you get the correct needle for the carb and run it on 25:1.
You can shorten the shaft length of a Seagull with a hacksaw - takes about 5 minutes. One of mine was shortened thus, then a couple of years later trip to a metal tube supplier to buy 3 new bits of metal lengthened it to an ultra-long shaft for a small cruiser.There may be no need for an adjusting collar. Most small dinghies are made with a transom board 15" above the waterline which is correct for your standard engine. However, many of the early inflatables such as Avons had lower transoms so we made a shorter engine (40 featherweight) with 13" shaft, but you could shorten the 40+ with the collar.
VicS has the dating correct. We ran a reconditioning service at that time and it is quite possible that your engine was originally used by a hire fleet - we had hundreds of engines on lakes and reservoirs on fishing boats etc and regularly reconditioned them for the operators. The R signifies that.
Lost in the mists of time! Record keeping was not a strong point in the old Seagull works, except engine numbers. A hire engine could be back for reconditioning after only one season, for example if it ended up at the bottom of a lake like the one I have. Was part of my induction to recondition it, and then I added all sorts of experimental bits to it and kept it when I left. A reconditioned engine could have parts from other engines and ended up looking like new, hence the need to put the R on the crankcase to avoid it being passed off as new.Hi, Many thanks for the reply and the history of my seagull. Do you have any idea how long they would have hired them out for? I wonder if anyone still has a recorded of when they went on hire and come off hire and then sold.
Hi, you are so knowledgeable and great to read the history of the engine. I wonder how many owners it has had. I bet quite a few.
Anyway going to test the engine and boat out to day in the harbour.![]()
May be covered later in the thread but I do not have time to check. There are a few points to add
0.5 Make sure you have a first aid kit to hand
1 Undo the air bleed on top of the tank
2 Let the fuel out of the tank by pulling the fuel tap out
2.5 Tell everyone else to lie down in the bottom of the boat
3 Tickle the carburettor till it floods
3.5 Give those that are not lying down one last warning
4 Flip down the metal choke
5 Set throttle to halfway or a little more
6 Ensure it’s in neutral – if there is one
7 Give it a smart pull
7.5 Start first-aid on the chap that sat up and got a good whipping from the pull cord
Been there - done that ...many times
Both of mine always started first pull. One was a 40+ that I bought new in mid-1960s, one a Century of unknown age. The 40+ started life as a short shaft for a sailing dinghy, three new lengths of pipe/rod converted it to a long shaft to push a small cruiser, which it sometimes did hours on end at a time, except for stops to refill tank. Then got legs cut down again to very short shaft for Avon inflatable dinghy when the next boat I bought came with the old Century. Both always ran on 10:1 cheap straight 30 motor oil. The 40+ once spent several tides underwater: on recovery washed and cleaned it, oiled it and fresh fuel and plug. Started immediately as usual, though very smokily for a few minutes because of all the extra oiling. Kept and used it years on from then.+1
every time - unlike the Jap I bought to replace it
. Don't have anyone stood within 4 or 5 feet. That cord really hurts if it hits you.
