Fr J Hackett
OK in the likely event that I am not allowed to dry out at Ramsholt is there anywhere local to the Orwell that it is possible and permitted.
Scrubbing posts at woolverstone or SYH, posts at Brightlingsea.OK in the likely event that I am not allowed to dry out at Ramsholt is there anywhere local to the Orwell that it is possible and permitted.
Thanks do I need to book them through the marina?
Aren't there scrubbing posts at Pin Mill too ?
Yes, but have never used them so can't help with contact etc.Thanks do I need to book them through the marina?
Felixstowe Ferry
Ooo interesting where and do you book through the sailing club.
Suffolk Yacht Harbour has a concrete base.
Book through the office (chandlery). Water & electric.
Visitors - £24.50 per tide
No current & very sheltered (mostly)
I'd always recommend a look see at LW a few days beforehand to check that it meets your requirements (I don't want any bad pressMany thanks for that it could well be the one.
Think you might find George will not let you use the hard unless you have a mooring there. May be worth a call. If you do use it you need someone on the quay to take your lines. Best time is High Water or you can get caught and finish up hitting the slipway. There is one ring and a small piece of tube for the outer line. Done it a couple of times if you don't get far enough in then you finish up in the mud towards the transom.
Ramsholt quay and slipway, plus a rather nice boat
2009 as I recall, after a trip from Wells to The Deben
Bit of a rough trip![]()
And a lot of mud as well unless things have changed since I was a lad![]()
