Rum_Pirate
What to coat the drive shaft splines to avoid it ‘sticking ‘ in future?
I like your wood set up- good stuff.
I would invest in 2x $20 hydraulic jacks and push the wood apart using them. Position them close to the forward long 10mm studs, in line with the engine drive shaft. Maybe put a ratchet strap (like a belt) around the engine and both jacks, to stop them pinging out.
This will provide more/better force than just winding the nuts.
Don’t worry about pulling uber hard. The seized shaft will come out long before the engine bearings /crankshaft thrust retaining elements break.
Just pump the hydraulic jacks very hard!
It isn’t the gear change linkage that is causing this problem. If it were that, the lower unit would move down a couple of multimeters. This is a seized drive shaft spline and /or seized dowels.
If you want to cut a hole in the side of the leg and blow torch the stuck splines then great, but try it cold first imho.
