Cruise Reports Dropping a jon boat when there's no boat ramp?
JosephTaylor
New Member
26 Nov 2019
Hello. I'm not sure if I'm in the right sub but I'll give this a try.
For work I have to drop a jon boat in an isolated lake, problem is there is muck of a 1 or 2 feet deep that's about 20 feet out so I can't back into the water with the trailer. This is really the only access point. Does anyone know of any equipment I can lay out there to help me?
As you cant drive to the water you'll need to slide your boat to the water. Maybe a modular floating pontoon such as the follwing could be an answer
https://www.dockmarine-europe.com/en/catalog/c48~flexiport
If its a small one on a trailer, then either a 'breakback' trailer or re route the winch cable over the rearmost roller then back to the bow - hence the winch will act to pull the boat off the trailer.
Only reverse in a short distance.
For work I have to drop a jon boat in an isolated lake, problem is there is muck of a 1 or 2 feet deep that's about 20 feet out so I can't back into the water with the trailer. This is really the only access point. Does anyone know of any equipment I can lay out there to help me?https://solitaire.onl/ 9apps.ooo/
issue got solved!!
How big of a boat? If it’s pretty small then you could just drop it off and drag it (wear hip boots). A slightly bigger one and you could probably push it on 2x4s. If you can’t do that then I’m out of ideas without seeing pictures share it installvidmate.com
A flat bottomed boat is ideal for getting over the mud as it slides a lot easier than a keeled.
Launch boat onto mud, put on wellies, lean on transom to stop you sinking into the mud and push. Boats move quite easy and you can travel quite a distance.
2nd method is to stand in boat and use oar over transom as lever against the mud.
Slower but cleaner. If boat does not move initially jump up while levering- boat moves!
Alternatively swop boat for hovercraft!
