zoidberg
I have a task to drill 8 holes in grp, each to admit 12.7mm machine screws with minimum tolerance. The grp moulding is 10-11mm thick and will be reinforced with ~6mm of fresh carbon fabric layup. These m'screws will secure 2 specialised 95mm OD deck-eyes using suitable locknuts and 120mm OD joint washer plates.
I'll need some specialised guidance on 'pre-load torque' but more urgently, whether to use a 12mm toothed Forstner drill bit, or a diamond-brazed hole saw bit....?
