Birdseye
Was a bit surprised to see this thread still going so I popped in depite the earlier offensive and childish comments of some posters.That is not at all what I'm saying....
I'll have one more go....
For any boat, from lightweight 30ft tris to bilge keelers, there is an optimum downwind angle to get downwind at the best VMG. These angles widen as the breeze drops. If your next leg is within the cone formed by these angles, such that you would have to sail lower than your optimum downwind VMG to get to it, then you will be faster sailing those angles (assuming good gybes etc) than you will be pointing straight at the mark, always. The slower the boat and the stronger the wind, the narrower those angles are. To the point where for more traditional boats in 15kts plus they are effectively 180. But even in traditional boats those angles will be wide in 6 knots of breeze. Look at those polars up thread, that's a 60 degree "cone" in 6kts of wind.
If you choose your downwind angle using VMG to waypoint, you are going to get it wrong on occasion. And those will be mostly when the mark is NOT dead downwind, but is off to one side, whilst still being within that cone. Under those circumstances is might look better on VMG to waypoint to sail just a bit lower and point straight at the mark.
BUT it isn't the instantaneous VMG to the mark that is the important measure, it's the total VMG to the mark over the course of the leg. If I sail a bit higher and faster than you, then my VMG to the waypoint might be a little slower initially. However, when I then gybe on the layline for the mark my entire boatspeed is now at the mark, and my boatspeed is higher than yours because I'm sailing higher, so my VMG is a lot higher. If my average VMG over the whole leg is higher, then I will arrive first. This is easy to see on the water, if I sail a hotter angle but am not going forwards relative to you such that a gybe will just take me back to you, or behind you, then your angle is better. If however I inch forward and get to a point where a gybe would take me clear across your bow, then I've sailed a better downwind angle, and despite your VMG to waypoint being initially higher than mine, I'm now ahead..
Golden rule of thumb is if your mark is within the cone, you always, always sail your best downwind angles. It is extremely rare to gain an advantage by sailing lower than your best downwind VMG over a leg of any length. Noting of course, as per my 1st post in this thread, that in reasonable breeze for the type of boat the OP is sailing, 180 degrees may well be the best angle.... But it certainly won't be in light winds.
This is simply about how to get downwind the fastest way possible. The application of tides, and which side of the course you should favour etc is a completely different topic. You are confusing how to sail the boat fast with tactics. Best upwind and downwind VMG angles are just about getting the most performance out of the boat. Deciding how to use that performance to position the boat on the race track to take advantage of tides or windshifts is tactics.
VMG is a vector so its meaningless to say VMG without saying what the velocity is towards. But as I read your post, I entirely agree with what you have said above. I am no more proposing that you should ignore speed through the water than you are saying I should ignore the waypoint. After all, the objective is to round the waypoint after sailing the fastest possible course, which in my case sailing in the Bristol channel has to include tides .
Out of interest I have done a few calculations using a polar, as it happens for my last boat which was a fin, and some maths. What that suggests is that the breakeven point for sailing at an angle rather than directly at a dead down wind mark is around the 10kn wind speed. Below you benefit as far off wind as 150deg, but once you get up to14kn wind then straight at the mark assuming its dead down wind, works better. The issue of course is the weight of the boat in relation to its sail area and keel drag - boat design is a key factor in the decision. Or to put it another way, how much faster your particular boat goes off the wind than it does dead down wind.
Bye!
