jfm
I look at paper charts but never put pencil on them. Just move the cursor on the plotter, join the dots electronically, and the autopilot drives the boat along the course. If I need to know my position I look at the plotter. I look at a second totally independent GPS to see that it says the same as the first, now and again, to confirm the GPS is working ok.
I cant understnad why you bother working out EPs. Whatever you compute, the GPS is the correct answer. If you dont trust the GPS, an EP wont help you. If a GPS computer goes nuts, it will likely give you a nutty position in Birmaingham and then it's obviously bust so at that point you start EP calcs from your log book. A GPS is unlikely to be just a bit out, like 5 miles. And if it were you would (mistakenly) believe the GPS not your EP. So the solution to worries over GPS set failure is to carry multiple GPS sets.
I agree you need a log on long trip. If all the computers bust you need to work out an EP. I dont like having the electronics store the log, because if they bust you lose the data. I therefore have a paper printer (the Navtex) that prints position, heading, course, speed, time, every 15 mins. If the electronics bust, I have paper record. And it's a much better record because the info is printed characters, same format, precise time intervals, etc. TCM you have this too only your printer is in the cupboard above the downstairs TV and you never remeber it's there and never turn it on.
