Tim-JS
My NMEA 2000 network recently stopped working, with my plotter showing the NMEA 2000 device list as "None Found".
I initially thought it might be a voltage problem, but testing a few places with a multi-meter showed that this was actually fine.
My investigations appear to point towards a problem with a drop cable, but it feels like these are quite simple so wonder if I'm missing something else significant ?
Of course I can buy a replacement but worry that it wont make a difference, so would appreciate if any NMEA 2000 experts can advise whether something else may be happening.
I suspect the full list isn't relevant, but (here it is anyway...) the network has the following components from one end to the other:
Inside the saloon at the chart table:
I thought this pointed to the "Garmin GPS19x-NMEA2000" being the issue, but interestingly when I connect the "Garmin GPS19x-NMEA2000" directly to a T piece on the backbone, either in the saloon or the starboard locker, all is well.
Tomorrow I'll check the voltage at the "Garmin GPS19x-NMEA2000" end of the drop cable, but wondered if there's anything else obvious that I should be checking ?
Appreciate your thoughts.
Thanks, Tim
- Terminator
- T piece with drop cable to power connection
- T piece with drop cable to Garmin GPSMap 5012
- Backbone cable start (A)
- Backbone cable end (A)
- T piece with drop cable start (B) (to "Garmin GPS19x-NMEA2000")
- T piece with drop cable to "Simrad RF25 _Rudder feed"
- T piece with drop cable to "Simrad FC40 _Flux compass"
- T piece with drop cable that connects both "Triton Display" and "Simrad OP10 Keypad" into the network
- Terminator
- Drop cable end (B) with "Garmin GPS19x-NMEA2000" attached
Thanks, Tim
