Spyro
let me get this right..
take 12v, use an inverter to make it into 240v and then plug in a laptop charger that transforms it back to ~12v
What am I missing?
A few amps at the end of it. Mostly converted into heat
What am I missing?
Does anyone know of one that has a connection that will fit a MacBook?
I too have had perfect success with this Maplin adaptor. The voltage is configurable, and I have used it for many different laptops with different voltages. For one laptop for whose plug was not in the range supplied, I hacked a wire off a mains charger, and soldered it on to a socket that the adaptor could plug into. It seems thus that, with even a modest amount of ingenuity, it is possible to charge a Mac.I used one of these for a number of years with no problems:
www.maplin.co.uk/120w-laptop-car-adaptor-44736
Far less power hungry than an inverter
Most are switched mode supplies, which should in theory be able to even take DC, so i can't think a Quasi-sine over a pure sine would matter at all.
That being said even if it shortens the life of your charger a little, the number you could buy with the saving should last you a lifetime.
Yes +1 on the 12V lighter plug converter, they are cheaper than inverters & usually come wiht lots of little plugs + variable voltage so you can use them to drive lots of DC transformer driven gimmicks. Works in your car as well![]()
