V1701
Evening all, thinking of using laptop & GPS mouse for navigating, if I do would a cheap inverter from ebay do the job or do I need a pure sine wave one?
Thanks,
David.
Thanks,
David.
some laptops are susceptible to less than perfect (clipped) AC wave form.
Why not look for a 12v car charger specifically for the laptop model ?
e.g. http://cgi.ebay.co.uk/12V-DC-Laptop...Accessories_PowerSupplies&hash=item27b982799e
Thanks,
David.
Thanks,
David.
Yes +1 on the 12V lighter plug converter, they ...usually come wiht lots of little plugs + variable voltage so you can use them to drive lots of DC transformer driven gimmicks. Works in your car as well![]()
Does anyone know of one that has a connection that will fit a MacBook?
Most laptops need 17-20V (there are a few small laptops and netbooks that run directly off 12v, but not many). A 12v laptop charger has a nominal input voltage of 12V, but the output voltage will be higher.let me get this right..
take 12v, use an inverter to make it into 240v and then plug in a laptop charger that transforms it back to ~12v
What am I missing?
^ the fact that the type of an inverter is an issue (DC to sine, triangular or any number of different wave forms) - and the horrible inefficiencies in going from DC to AC to DC again, I guess.
